Can't test with different versions of .pxObjClass
I have a when rule that's logic is checking for .pxObjClass.
When I created a test case with different values the test fails, since pxObjClass is unmodifiable.
I supplied different values for .pxObjClass using the "Multiple input combinations" checkbox. (the default test case created only had a blank pxObjClass, which should never occur in my situation.)
Warnings
The page or property RunRecordPrimaryPage.pxObjClass is unmodifiable. Calling method: com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.setValue(Object) Details: property is reserved.
How can I set up a test case to fully cover this when rule with different pxObjClass values specified in different input combinations?
