Can't get unit testing to work in 7.1.7 PE
I am trying to understand unit testing in Pega. I created a simple activity "Id" that I would like to test. Id has one required in parameter X, one out parameter Y, and does Property-Set(Param.Y, Param.X).
I tried testing from "menu Actions > Run" and from "tab Test Cases > Record new test case". I chose various parameters and tried entering various values (including no value) for X and Y, but I can't get anything other than an "ActivityStatusSuccess" window that shows a green checkmark and says: Status: good; Message: The Operation completed successfully, but returned no content; [...].
How can I get something meaningful, e.g. a test failing if I enter different values for X and Y?
Also maybe the help [1] should be updated; what it describes doesn't seem to match the existing interface.
Your question has been forwarded to subject matter expert(s) and we hope to have an answer for you soon.
Thank you for your patience.
Kind regards,
Bob Lloyd
PDN and Pega Academy Self-study Forums Support Team
