Flow Action failing when starting Customer NBA Interaction
When running the first execise the Flow Action fails - see atached screenshot. Is there anything which can be done to fix this?
Bryan,
As discussed in our off-line conversation, thanks a lot for letting us know that setting the Network Adapter (that was defaulting to "NAT") to "Host Only" did the trick.
Marco.
