Capgemini
ERROR - Unexpected exception caught while trying to send an email message with sender ID of < [email protected] > and addressee of < [email protected] >:
Any thought about below error
ERROR - Unexpected exception caught while trying to send an email message with sender ID of < Proprietary information hidden> and addressee of < Proprietary information hidden>:
javax.mail.MessagingException: Can't send command to SMTP host;
We are getting this exception in our production log. This is happening intermittently. We did test connectivity of the email account and the result is good.
We have more than 1000 mails triggered from this email account and out of which few (10-15 ) are getting this error which is creating a fix correspondence assignment and mail is not getting delivered to recipient.
We have worked with our network team and troubleshoot the issue but they are saying connectivity is good also we continuously pinked the email server but there is packet break found.
***Edited by Moderator Marissa to add SR Details***
Capgemini
Ravi Ramineni
Capgemini
SR-B66270
Are you trying to send bulk emails ?
Capgemini
No
Capgemini
This is happening in case of single email also.
Did you find solution to this problem ? Even I am facing the same issue while configuring new SMTP server. if you have the solution pls share.
J Sainsbury's plc
we are facing the same issue while sending the bulk mails.
CapGemini
I got the same exception in log while sending bulk emails through PEGA. Please provide the information to overcome this.
Suppose we are trying to send emails more than 5 then few of those emails are not delivered to Recipient and same exception caught in log.
Anupama
Did you find solution to this problem ? I am also facing the same issue.
Capgemini
We did not find any solution to fix at PRPC end.
So our SysOps team provided a dedicated SMTP which eventually solved our issue.
Kindly be remember that we were getting SMTP response as “421 4.4.2 Message submission rate for this client has exceeded the configured limit“
Moumita Dutta
