Distribution Test with volume constraint not working in pega 8.4
We tried to run a distribution test using volume constraint and it failed with below error
Failed to apply volume constraint. Review and update the campaign to resolve the issue and re-run the distribution test.
I tried to analyze the issue from my side and I found that we have a function in pega ApplyProgressiveOptimization which is responsible for applying volume constraint but I could see some exception in this function in logs as below:
2021-05-17 10:06:24,924 [fault (self-tuning)'] [ STANDARD] [ ] [ AOM:02.01.01] ( api.dataflow.DataFlows) ERROR 10.221.32.139|10.18.203.61 AOMAdmin - Unable to find dataflow rule [VF-AOM-Data-Customer-SEGC1952VDFClubLoyalty13M.DFPRTest189]
2021-05-17 10:06:24,926 [fault (self-tuning)'] [ STANDARD] [ ] [ AOM:02.01.01] (flow.service.DataFlowRunConfig) ERROR 10.221.32.139|10.18.203.61 AOMAdmin - Cannot get the dataflow [VF-AOM-Data-Customer-SEGC1952VDFClubLoyalty13M.DFPRTest189] defined by this configuration. Will assume it's neither resumable nor stream for the resilience configuration
2021-05-17 10:06:24,938 [fault (self-tuning)'] [ STANDARD] [ ] [ AOM:02.01.01] ( api.dataflow.DataFlows) ERROR 10.221.32.139|10.18.203.61 AOMAdmin - Unable to find dataflow rule [VF-AOM-Data-Customer-SEGC1952VDFClubLoyalty13M.DFPRTest189]
2021-05-17 10:06:27,616 [fault (self-tuning)'] [ STANDARD] [ ] [ AOM:02.01.01] (.ProgressiveOptimizationEngine) ERROR AOMAdmin - ProgressiveOptimizationEngine.applyConstraintToPartition() - Exception processing Volume Constraint
2021-05-17 10:06:27,637 [fault (self-tuning)'] [ STANDARD] [ ] [ AOM:02.01.01] (PegaMKT_Work_ProgramRun.Action) ERROR AOMAdmin - Failure in ExecuteProgramRun: Failed to apply constraint.:PRTest-189
2021-05-17 10:06:28,126 [fault (self-tuning)'] [ STANDARD] [ ]
Can anyone please help me on this?
Taniya
***Edited by Moderator: Pooja Gadige to add support case created tag***
