Accenture
Last activity: 17 Feb 2021 3:04 EST
Child Case Issue, Data transform does not automatically create to populate the child case with data from the parent
I have a issue with my Car Rental Application. However this only happens on this specific case and not on other cases I have created. Let me walk you through my first stage:
- Collect Customer Information step
- New Process
- Create Case Step
- Wait Step
- New Process
Here is how I configured my child case.
In App studio I select the Insurance case type on the right, and I select the check box "Transform information to a new case" and then select all fields from the "'From'field" column and tick the "Add mapped fields".
Now this is where things go wrong. If I save and run it fails to load into my child case due the the data transform. Once I save in App studio I see on the Child Case step "This step has advanced configuration set at Dev Studio" and I must go there to see any further settings to do with my Create Case step. Now upon selecting my Create Case step in Dev Studio I see the data transform assigned to the step has the same name as the step, but it is not already created.... I click the cross hairs to the right of the data transform, but instead of opening a configured data transform like what should have happened, it prompts me to create and open and configure this new data transform from scratch.
In other cases I have created I do not see this behaviour, and I am able to successfully populate the child case with data from the parent case using the above steps.
Is this something that I have accidentally caused? I have tried deleting the steps and process and starting again in the same case but to no avail. has anyone seen this behaviour before and knows how I could fix it?
This is all happening on 8.5 on the Pega community trial edition
