Cases Stuck in Broken Process
So I have a requirement to do some clean up work for some cases. I have several assignments that were incorrectly routed and are now part of the broken process flow. Is there a way to either change the stage or restart the flow process for multiple assignments? I tried using the pxRestartStage activity, however when I refresh the case there are multiple assignments. Once assignment is correct and at the beginning stage, the other assignment is still in the broken process. How to I restart or move the assignment completely out of broken process stage?
