Red Alpha
Last activity: 21 May 2025 14:47 EDT
Duplicate Case Check Resulting in Broken Process Error
My team and I are working on a case type which included a duplicate check in between the first and second steps of a multistep form. The case type we are working on inherits from another case type in our application due to the highly similar data models. The new case type we are working on routes the multistep form to a work queue for processing and completion. The duplicate check configured in this new case type hinges on two properties, so it's processing should be rather straightforward. However, when I go to test the case type, once I make it through the first step in the multistep form to the duplicate check a Broken Process assignment comes up. When I click "Go" on the Broken Process assignment an error is shown stating "Unauthorized access for the given parameter ID". The case type that this new case type inherits from does not have any issues with is duplicate check. Any ideas on how to debug this or resolve this issue would be greatly appreciated!
Update: I tweaked the duplicate conditions slightly and received a new error message as depicted in dupequestion4.png. Does this error message mean it is trying to reference an Operator record called "Releasers"? Releasers is the name of the work queue the steps in this multistep form are routed to.
@TessPorter Received the following explanation from Pega Support:
I believe the problem here is the multi-step form. Typically multi step forms meant to behave as a single task, broken up into several screens to be processed one after another by a single user, and the assignments for each screen are automatically assigned to that user (or in this case, the workbasket). When a duplicate search finds a duplicate case, it creates a worklist assignment for the user. Because of the multi-step form context being aligned to the workbasket, the process attempts to create a worklist assignment and fails because the multi-step form is assigned to the workbasket.
From case designer, adding a duplicate search step to a multi step form is not possible. While one can be added via the flow ruleform, the OOTB Duplicate Search subflow shape is designed to create a worklist assignment. I would recommend leveraging standard stage steps surrounding your duplicate search, rather than a multi step form. In my local testing, this approach did not encounter the same error.
If a multi step form is explicitly required in this scenario, you might be able to customize the OOTB pyDuplicateSearch flow for this case type to change it's assignment's routing configuration, however assistance with such customization would be outside the scope of a support requests.
