Merkle
Last activity: 23 Sep 2019 11:02 EDT
Campaign failed with Exception in stage: Offer Flow Suspend and Update the campaign to resolve this issue
We are running a campaign and getting error as below. Would you kindly help us to understand the root cause or what action we could take to resolve this?
Thank you!
Checked in the log and below is the log message:
Thank you!
api.dataflow.DataFlow) ERROR - Supressing an exception from status subscriber onNext com.pega.dsm.dnode.api.DNodeException: Unable to release lock on [Data_Flow_Lock_For_ASSIGN-DDF PR-2938!DIST72STATUS_CHANGE] at com.pega.dsm.dnode.impl.dataflow.manager.DataFlowLockManager.unlock(DataFlowLockManager.java:58) at com.pega.dsm.dnode.impl.dataflow.manager.WorkPersistenceManager.saveWithStatusChange(WorkPersistenceManager.java:156) at com.pega.dsm.dnode.impl.dataflow.manager.WorkPersistenceManager.save(WorkPersistenceManager.java:130) at com.pega.dsm.dnode.impl.dataflow.manager.DataFlowMetricsSubscriber$AssignmentUpdater.updateWith(DataFlowMetricsSubscriber.java:156) at com.pega.dsm.dnode.impl.dataflow.manager.DataFlowMetricsSubscriber.onNext(DataFlowMetricsSubscriber.java:55) at com.pega.dsm.dnode.impl.dataflow.manager.DataFlowMetricsSubscriber.onNext(DataFlowMetricsSubscriber.java:25) at com.pega.dsm.dnode.api.dataflow.DataFlow$1$2.onNext(DataFlow.java:234) at com.pega.dsm.dnode.api.dataflow.DataFlow$1$2.onNext(DataFlow.java:228) at com.pega.dsm.dnode.api.dataflow.DataFlow$1.emit(DataFlow.java:156) at com.pega.dsm.dnode.impl.stream.DataObservableImpl.subscribe(DataObservableImpl.java:56) at com.pega.dsm.dnode.impl.dataflow.manager.LocalRun.execute(LocalRun.java:149) at com.pega.dsm.dnode.impl.dataflow.manager.LocalRun.lockAndRun(LocalRun.java:87) at com.pega.dsm.dnode.impl.dataflow.manager.LocalRun.run(LocalRun.java:63) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at com.pega.dsm.dnode.impl.prpc.PrpcThreadFactory$PrpcThread.run(PrpcThreadFactory.java:81) Caused by: com.pega.pegarules.pub.database.LockGoneException: Database-LockFailure-LockLost Data_Flow_Lock_For_ASSIGN-DDF PR-2938!DIST72STATUS_CHANGE From: (B17ABCCCF0E0040267BA0ECFB7F59B2CF) SQL: select pxOwnerId as "pxOwnerId", pxUpdateOperator as "pxUpdateOperator", pxUpdateOpName as "pxUpdateOpName", pxExpireDateTime as "pxExpireDateTime", pxUpdateDateTime as "pxUpdateDateTime", pxLockHandle as "pxLockHandle", pxCreateDateTime as "pxCreateDateTime", pxUserHost as "pxUserHost" from PEGA_DATA.pr_sys_locks where pzInsKey = ? SQL Inserts: <Data_Flow_Lock_For_ASSIGN-DDF PR-2938!DIST72STATUS_CHANGE> at com.pega.pegarules.data.internal.access.DBLockProviderImpl.releaseLock(DBLockProviderImpl.java:834) at com.pega.dsm.dnode.impl.dataflow.manager.DataFlowLockManager.unlockWithLockProvider(DataFlowLockManager.java:82) at com.pega.dsm.dnode.impl.dataflow.manager.DataFlowLockManager.unlock(DataFlowLockManager.java:56) ... 15 more 2019-09-18 09:53:54,855 [-threads-1000418060)] [ STANDARD] [ ] [ AAMKT:01.21.01] (PegaMKT_Work_ProgramRun.Action) ERROR - Failure in ExecuteProgramRun: Exception in stage: Offer Flow
