Nationale Nederlanden
Last activity: 27 Sep 2021 10:12 EDT
Assembled classes schema: null
During the PRPC upgrade the upgrade.bat stops at the step:
[java] 2021-09-27 15:09:14,342 ( SQLLoaderInternal) INFO - Statement: UPDATE PEGAR.PR4_RULE_VW [java] SET pzRuleSetVersionMinorPatch = [java] CASE [java] WHEN pyRuleSetVersion IS NULL THEN '-1' [java] ELSE SUBSTR(pyRuleSetVersion, 4) [java] END [java] WHERE pzRuleSetVersionMinorPatch IS NULL [java] [java] com.ibm.db2.jcc.am.SqlWarning: DB2 SQL Warning: SQLCODE=100, SQLSTATE=02000, SQLERRMC=null, DRIVER=4.19.72 [java] at com.ibm.db2.jcc.am.b4.b(b4.java:215) [java] at com.ibm.db2.jcc.am.b4.b(b4.java:281) [java] at com.ibm.db2.jcc.am.kh.c(kh.java:2806) [java] at com.ibm.db2.jcc.am.kh.d(kh.java:2776) [java] at com.ibm.db2.jcc.am.kh.b(kh.java:2143) [java] at com.ibm.db2.jcc.t4.ab.i(ab.java:226) [java] at com.ibm.db2.jcc.t4.ab.c(ab.java:48) [java] at com.ibm.db2.jcc.t4.p.b(p.java:38) [java] at com.ibm.db2.jcc.t4.av.h(av.java:124) [java] at com.ibm.db2.jcc.am.kh.ak(kh.java:2138) [java] at com.ibm.db2.jcc.am.kh.a(kh.java:3325) [java] at com.ibm.db2.jcc.am.kh.e(kh.java:1108) [java] at com.ibm.db2.jcc.am.kh.execute(kh.java:1087) [java] at com.pega.pegarules.install.SQLLoaderInternal.readAndExecuteSQLStatements(SQLLoaderInternal.java:151) [java] at com.pega.pegarules.install.SQLLoaderInternal.load(SQLLoaderInternal.java:110) [java] at com.pega.pegarules.install.SQLLoader.loadInner(SQLLoader.java:98) [java] at com.pega.pegarules.install.SQLLoader.load(SQLLoader.java:77) [java] at com.pega.pegarules.install.SQLLoader.main(SQLLoader.java:65) [java] 2021-09-27 15:09:14,343 ( SQLLoaderInternal) INFO - Processing complete. [echo] ***setting resume checkpoint*** [propertyfile] Updating property file: C:\temp\Pega_7.4\01_Pega_7.4\scripts\resume.properties
Apply UDFs:
Apply UDFs Inner: [echo] ***setting resume checkpoint*** [propertyfile] Updating property file: C:\temp\Pega_7.4\01_Pega_7.4\scripts\resume.properties
Engine Load:
Engine Load Inner: [java] 2021-09-27 15:09:15,455 (com.pega.pegarules.internal.bootstr) 1050 - Loading bootstrap properties from file:///C:\Users\mboer\AppData\Local\Temp\/PegaInstallTemp-27-September-2021-15.00.32/prbootstrap.properties [java] 2021-09-27 15:09:15,460 (com.pega.pegarules.internal.bootstr) INFO - Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup [java] 2021-09-27 15:09:15,461 (com.pega.pegarules.internal.bootstr) INFO - Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup [java] 2021-09-27 15:09:15,462 (com.pega.pegarules.internal.bootstr) 1050 - Unable to locate archive.properties properties, setting warVersion to -1 [java] 2021-09-27 15:09:15,462 (com.pega.pegarules.internal.bootstr) 1050 - Engine schema defined in allclasses: null [java] 2021-09-27 15:09:15,463 (com.pega.pegarules.internal.bootstr) INFO - Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup [java] 2021-09-27 15:09:15,463 (com.pega.pegarules.internal.bootstr) INFO - Could not find prconfig in the local JNDI context, skipping prconfig setting lookup [java] 2021-09-27 15:09:15,463 (com.pega.pegarules.internal.bootstr) 1050 - Engine classes schema: null [java] 2021-09-27 15:09:15,464 (com.pega.pegarules.internal.bootstr) 1050 - Assembled classes schema: null
So I wait for a very long time but still no progress. Any clue why it is not continue with the next step? Regards,
Maurice Boer
