Installation stopped in: 1050 - Assembled classes schema: null with no errors
Hi Team,
In the process of PEGA 7.2.2 instalation via UI tool, installation process stoped with no errors in with the log below.
UI tool dosen't shows any errors. in output or Error tab and process dosen't stoped. But there is no progress after the below mentioned step.
enerate_install_ddl:
Apply DDL:
Apply DDL Inner:
Apply UDFs:
Apply UDFs Inner:
Engine Load:
Hi Team,
Apply DDL:
Apply DDL Inner:
Apply UDFs:
Apply UDFs Inner:
Engine Load:
Engine Load Inner:
[java] 2017-03-24 12:57:55,026 (com.pega.pegarules.internal.bootstr) 1050 - Loading bootstrap properties from file:///C:\Users\1556598\Desktop\RDDT\install\temp/PegaInstallTemp-24-March-2017-12.56.24/prbootstrap.properties
[java] 2017-03-24 12:57:55,044 (com.pega.pegarules.internal.bootstr) INFO - Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
[java] 2017-03-24 12:57:55,050 (com.pega.pegarules.internal.bootstr) INFO - Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
[java] 2017-03-24 12:57:55,054 (com.pega.pegarules.internal.bootstr) 1050 - Unable to locate archive.properties properties, setting warVersion to -1
[java] 2017-03-24 12:57:55,057 (com.pega.pegarules.internal.bootstr) 1050 - Engine schema defined in allclasses: null
[java] 2017-03-24 12:57:55,059 (com.pega.pegarules.internal.bootstr) INFO - Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
[java] 2017-03-24 12:57:55,061 (com.pega.pegarules.internal.bootstr) INFO - Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
[java] 2017-03-24 12:57:55,063 (com.pega.pegarules.internal.bootstr) 1050 - Engine classes schema: null
[java] 2017-03-24 12:57:55,066 (com.pega.pegarules.internal.bootstr) 1050 - Assembled classes schema: null
Could some one help me on this.
Aruldevan
