Getting an error while Configuring Pega CTI Link with Amazon Connect
Hi Team,
We are encountering an issue while configuring the connection between Pega Call and Amazon Connect services.
Following the instructions in the Pega Call Implementation Guide CTI Link and the Amazon Connect Intelligent CTI for Pega Customer Service - Pega - Proof of Concept Proof of Concept (POC) documentation, we attempted to enable the connection. However, we are facing the following issues:
In the "Telephony Experience" Configuration Wizard, under the "Telephony Control" tab, clicking the "telephone" icon to make a test call redirects us to the AWS login portal. After logging in and successfully placing a test call, the AWS portal displays a blank screen with the message: "AWS has refused to Connect."
Additionally, upon clicking the "Next" button, an error message appears (please find the screenshot attached).
Could you kindly advise:
- Whether we missed any configuration steps.
- If the process we followed aligns with the correct procedure or if there is an alternative way to enable the connection.
- What is the configuration process that needs to be completed on the Pega side as well as the AWS Connect side?
Note: We are Using Pega Infinity Version 23 (Pega Customer Service - Pega Call)
Your guidance on resolving this issue would be greatly appreciated. Thank you, Koti.
