Capgemini
SE
Last activity: 14 Aug 2024 11:11 EDT
Unable to find this configuration "Show Additional Details" in Table using Constellation
I am exploring constellation portal and how to display a list of work objects in a table. This works well using a data page and i can configure a hyperlink on the case ID field which opens the work object. This is possible by using the below configuration.
However , i have another requirement where i want to achieve something similar for Data objects. My data page is created in my data class sourced to report definition. I can see the list of records in the table. However the data stored in the table has a lot of columns and BLOB. so i want to launch a view or open the data object to show all the fields from BLOB. But in this case, i do not see a similar option "Show additional details".
Has anyone have experienced this issue or found the root cause on why this configuration is only available for Work objects ? Or may be i have missed some configuration on my data class due to which i do not see this option.
Roshan
