How to uncheck "Validate Physician Details" when there are validation errors on pyworkpage
SCENARIO:
On click of submit; when finish assignment is run, then validation errors occur(if any) on PyWorkPage and also in current section. If there are no errors flow moves forward
If there are errors, again current screen comes up
If this is the case, then already checked "Validate Physician Details" must be unchecked automatically
APPROACH USED:
A DT Is called on custom SUBMIT (before finish assignment, on Actions tab) which sets Validate Physician Details checkbox to false, if there are any errors in pyworkpage
PROBLEM FACED:
This is working, only from second time as for the first time when SUBMIT is pressed, then DT would be run first and at the last validations,FINISH ASSIGNMENT was run(by pega)
For the first time as validations on flow action are still not processed, no errors would occur on pyworkpage and hence Checkbox is not unchecked
SUPPORTING SCREENSHOTS:
SCENARIO:
APPROACH USED:
PROBLEM FACED:
SOLUTION: ?
