Pega Upgrade from 7.2.x and 7.4 to Pega 8.x
We are planning to upgrade our Pega 7.2.x Instance and Pega 7.4 Instance to a single Pega 8.x instance.
What is the best approach to follow to have all the applications running on 7.2.x and 7.4 to run on Single Pega 8.x instance?
Hi @sumarao9: When you say 2 different versions of PEGA to be merged to single 8.x instance, basically you are trying to merge 2 code base / 2 DB into single code version / DB. What I would suggest is either of the below.
Few impacted areas which you need to be careful:
As a alternate, check if process fabric can solve your problem of merging.
Also please refer: https://support.pega.com/question/merge-two-different-pega-instances-one-instance
Thanks.
