Not able to authenticate using Pega administrator ID after Pega upgrade from 5.5 to 7.4
As per5 logs iRulestack for profile setup is being done from all 5.5 ruleset version.
Caused by: com.pega.pegarules.pub.generator.RuleNotFoundException: pyVTable-RuleNotFound-NoMatches RULE-OBJ-ACTIVITY SHOWDESKTOP Data-Portal 2 The 2 rules named 'SHOWDESKTOP' defined in the rulebase are:
2 related to applies-to class 'Data-Portal', but were defined in rulesets which are not in your rulesetlist: {Pega-Desktop:07-10-35, Pega-WB:07-10-01}.
Current RulesetList:
[email protected]:,
Pega-ProCom:05-05,
Pega-IntSvcs:05-05,
Pega-WB:05-05,
Pega-RULES:05-05
[email protected]:,
Pega-ProCom:05-05,
Pega-IntSvcs:05-05,
Pega-WB:05-05,
Pega-RULES:05-05
at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolver.throwDetailedRuleNotFoundException(VirtualTableResolver.java:733) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolver.resolveToCandidate(VirtualTableResolver.java:429) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolver.resolveToContainer(VirtualTableResolver.java:380) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolver.resolveRule(VirtualTableResolver.java:149) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.VirtualTableImpl.resolveRule(VirtualTableImpl.java:370) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.PRGenProviderImpl.get(PRGenProviderImpl.java:550) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3404) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646) ~[prprivate.jar:?]
***Edited by Moderator Marije to change type from Pega Academy to Product, added Product details and Capability tags****
