Nationale Nederlanden
Last activity: 7 Aug 2023 10:33 EDT
Assembled classes schema: null
During the PRPC upgrade the upgrade.bat stops at the step:
[java] 2021-09-27 15:09:14,342 ( SQLLoaderInternal) INFO - Statement: UPDATE PEGAR.PR4_RULE_VW
[java] SET pzRuleSetVersionMinorPatch =
[java] CASE
[java] WHEN pyRuleSetVersion IS NULL THEN '-1'
[java] ELSE SUBSTR(pyRuleSetVersion, 4)
[java] END
[java] WHERE pzRuleSetVersionMinorPatch IS NULL
[java]
[java] com.ibm.db2.jcc.am.SqlWarning: DB2 SQL Warning: SQLCODE=100, SQLSTATE=02000, SQLERRMC=null, DRIVER=4.19.72
[java] at com.ibm.db2.jcc.am.b4.b(b4.java:215)
[java] at com.ibm.db2.jcc.am.b4.b(b4.java:281)
[java] at com.ibm.db2.jcc.am.kh.c(kh.java:2806)
[java] at com.ibm.db2.jcc.am.kh.d(kh.java:2776)
[java] at com.ibm.db2.jcc.am.kh.b(kh.java:2143)
[java] at com.ibm.db2.jcc.t4.ab.i(ab.java:226)
[java] at com.ibm.db2.jcc.t4.ab.c(ab.java:48)
[java] at com.ibm.db2.jcc.t4.p.b(p.java:38)
[java] at com.ibm.db2.jcc.t4.av.h(av.java:124)
[java] at com.ibm.db2.jcc.am.kh.ak(kh.java:2138)
[java] at com.ibm.db2.jcc.am.kh.a(kh.java:3325)
[java] at com.ibm.db2.jcc.am.kh.e(kh.java:1108)
[java] at com.ibm.db2.jcc.am.kh.execute(kh.java:1087)
[java] at com.pega.pegarules.install.SQLLoaderInternal.readAndExecuteSQLStatements(SQLLoaderInternal.java:151)
[java] at com.pega.pegarules.install.SQLLoaderInternal.load(SQLLoaderInternal.java:110)
[java] at com.pega.pegarules.install.SQLLoader.loadInner(SQLLoader.java:98)
[java] at com.pega.pegarules.install.SQLLoader.load(SQLLoader.java:77)
[java] at com.pega.pegarules.install.SQLLoader.main(SQLLoader.java:65)
[java] 2021-09-27 15:09:14,343 ( SQLLoaderInternal) INFO - Processing complete.
[echo] ***setting resume checkpoint***
[propertyfile] Updating property file: C:\temp\Pega_7.4\01_Pega_7.4\scripts\resume.properties
Apply UDFs:
Apply UDFs Inner:
Engine Load:
Engine Load Inner:
[java] 2021-09-27 15:09:15,455 (com.pega.pegarules.internal.bootstr) 1050 - Loading bootstrap properties from file:///C:\Users\mboer\AppData\Local\Temp\/PegaInstallTemp-27-September-2021-15.00.32/prbootstrap.properties
[java] 2021-09-27 15:09:15,460 (com.pega.pegarules.internal.bootstr) INFO - Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
[java] 2021-09-27 15:09:15,461 (com.pega.pegarules.internal.bootstr) INFO - Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
[java] 2021-09-27 15:09:15,462 (com.pega.pegarules.internal.bootstr) 1050 - Unable to locate archive.properties properties, setting warVersion to -1
[java] 2021-09-27 15:09:15,462 (com.pega.pegarules.internal.bootstr) 1050 - Engine schema defined in allclasses: null
[java] 2021-09-27 15:09:15,463 (com.pega.pegarules.internal.bootstr) INFO - Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
[java] 2021-09-27 15:09:15,463 (com.pega.pegarules.internal.bootstr) INFO - Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
[java] 2021-09-27 15:09:15,463 (com.pega.pegarules.internal.bootstr) 1050 - Engine classes schema: null
[java] 2021-09-27 15:09:15,464 (com.pega.pegarules.internal.bootstr) 1050 - Assembled classes schema: null
So I wait for a very long time but still no progress. Any clue why it is not continue with the next step?
Maurice Boer
