HealthFirst
HealthFirst
HealthFirst
Posted: Feb 26, 2021
Last activity: Aug 7, 2023
Last activity: 7 Aug 2023 10:34 EDT
Libraries are failing while compiling after upgrade in from Pega 8.2 to Pega 8.5
Post upgrade to Pega Plat form 8.5 , libraries failing to compile. getting below errors.
Show More
Error(s) detected while generating java. Compiler reported: ---------- 1. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 59) import com.aspose.barcode.barcoderecognition.*; ^^^^^^^^^^ The import com.aspose cannot be resolved ---------- 2. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 60) import com.aspose.pdf.*; ^^^^^^^^^^ The import com.aspose cannot be resolved ---------- 3. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 61) import com.aspose.pdf.devices.*; ^^^^^^^^^^ The import com.aspose cannot be resolved ---------- 4. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 69) import com.aspose.barcode.*; ^^^^^^^^^^ The import com.aspose cannot be resolved ---------- 5. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 70) import com.aspose.cells.*; ^^^^^^^^^^ The import com.aspose cannot be resolved ---------- 6. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 73) import javapasswordsdk.*; ^^^^^^^^^^^^^^^ The import javapasswordsdk cannot be resolved ---------- 7. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 74) import javapasswordsdk.exceptions.*; ^^^^^^^^^^^^^^^ The import javapasswordsdk cannot be resolved ---------- 8. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 75) import com.tivoli.tec.event_delivery.EDException; ^^^^^^^^^^^^^^ The import com.tivoli.tec cannot be resolved ---------- 9. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 76) import com.tivoli.tec.event_delivery.TECAgent; ^^^^^^^^^^^^^^ The import com.tivoli.tec cannot be resolved ---------- 10. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 77) import com.tivoli.tec.event_delivery.TECEvent; ^^^^^^^^^^^^^^ The import com.tivoli.tec cannot be resolved ---------- 10 problems (10 errors) Compile failed.
Show Less
***Edited by Moderator Marissa to change type from Product to Upgrade***
