Accenture Federal Services
Last activity: 20 May 2021 10:41 EDT
Notification Utility Shape not working
I have an flow in my case that runs several ootb notification utility shapes. All of them work except one, where I am experiencing several issues. Through tracing the notification queue and the operators that run the process to kick off the notification, I have discovered that the notification is not receiving any recipients and therefore does not get sent. When I look at the clipboard, however, the property used to query the data page exists and is accurate and when I run the data page with that parameter it returns the expected result. I have no idea why the notification rule would not be able to find the operator and append them as the recipient. This notification does work if I call pxNotify from a utility shape activity and directly reference the property containing the name of the user, but I would prefer to use ootb functionality if possible.
Notification Utility Shape:
Notification Definition:
Notification Recipients Parameters:
pyWorkPage:
GetOperator Data Page Run:
