Cognizant
Posted: Jul 13, 2020
Last activity: May 7, 2021
case not appearing in the application which are are created using Pega Rest cases API
Case created successfully by Pega Rest cases API without any error
- Not able to see case in the work class instances
- But able to see assignment in the assign-workbasket instances
Created case present in the data base and also not able to fetch by using report definition also. It is strange issue and could you please provide inputs on this.
