Email Correspondence is attached to cases but no mail sent to User
Email Correspondence has been attached to the case, but user din't receive mail.
Version: Pega 8.1
Lokesh
***Edited by Moderator Marissa to update platform capability tags; product/version tag; change from Pega Academy to Product****
Can you check if your SendCorr agent is running correctly? Any broken instance maybe?
Hi MarcLasserre_GCS,
The Agent was running correctly, there is no broken queue.
On click of correspondence, confirm if you can see the Sent label with timestamp to confirm an email was sent from Pega successfully.
Sent: | Feb 19, 2019 12:07:55 PM From <SYSTEM NAME> |
If YES, I would recommend to check the SENT folder on the configured Sender email account mailbox & confirm if an actual email has been sent to the recipient. There could be mail delivery issues.
Let us know if that helps!
Hi Harish_GCS,
I'm able to see the Timestamp in the sent label.
There is no item in the SENT Folder
Hi Lokesh,
You can debug this issue by splitting the implementation into chunks.
1. Check Email Account:
Verify if you have a valid SMTP connection to send Outbound emails. Do a test connectivity and ensure the connection to email server is success. If it isnt success, then you need to verify if there is any firewall restrictions to use the given SMTP Host. Get it enabled
2. Send an Email:
For testing purpose, Create a wrapper activity and define the Correspondence information and call the OOTB SendSimpleEmail activity to trigger an outbound email. Trace it. Add steps to print more info in logs (before and after sending email)
SendCorr OOTB activity will be called which will queue this email in Pega-ProCom's SendCorr Agent for outbound processing. Trace this agent.
3. Receive Email:
Ensure the email is not moved to receiver's Junk folder due to default Id marked while sending it. (Prefer opensource email id like gmail for testing)
4. Verify DB Tables:
If you are calling this activity from your work object, ensure you audit and track it from DB tables associated with LINK-ATTACHMENT, DATA-WORK-ATTACH by checking Data-Corr-Email as a class reference.
Looking forward to hear from you.
Are you getting the mail without attachment or not getting the mail at all?
Could you please let us know the application server you are using.
Thank You,
I am facing the same issue, Emails are getting attached to case but not seen in User's inbox or in the Sent items from where the email was sent.
Pega - 8.6.3
SendCorr running on all nodes, no exceptions.
