    Capgemini
Last activity: 5 Feb 2018 17:41 EST
BIX on the cloud - BIX/sharedpath DSS
We are using Pega 7.2.2 and have configured BIX in a cloud based environment. The BIX/sharedpath DSS (with Owning ruleset as Pega-RULES) have been set to the location setup by cloud team and the csv extracts are getting generated properly in that location.
We have multiple projects in the shared environment and now are deliberating between options to segregate the BIX files generated by different applications. Since the DSS BIX/sharedpath holds the directory location where the files are going to be generated and we cannot make this path separate for different applications (since creating the DSS with an application specific owning ruleset doesn't work), it seems like the only option we have is to use different file masks in the BIX file listener which is supposed to process the files from the sharedpath directory location.
Is there any other option of achieving this kind of a segregation across applications, without having to use different file masks. Or is this the only option?
Thanks for your inputs and suggestions.
