Help with DSS Error in Pega23 on AWS Cloud
Hello everyone,
I’m in the process of installing Pega23 on AWS, and most things are running smoothly. However, when I try to create a new application using the Constellation, the portal displays a DSS error. I followed the documentation (https://docs.pega.com/bundle/platform/page/platform/deployment/constellation/constellation-pega-static.html) and set the dss ConstellationSvcURL to http://release.constellation.pega.io, but I’m still encountering a white screen when attempting to run a new case.
Is there a known solution to this issue, or a way to check the logs related to this? For context, the web server is running inside a Docker container.
Thanks in advance!
