Maantic Inc
Maantic Inc
Maantic Inc
Posted: Jul 7, 2017
Last activity: Jul 11, 2017
Last activity: 11 Jul 2017 3:50 EDT
How to add section display in Email body content.
Email is send in scheduled report and section has repeating grid table display.
#Reporting #email #pega7.2
Are you referring to the email being sent as part of a scheduled report? And you want to include section in the notification message? If not then kindly elaborate your requirement to propose some solution.
Are you referring to the email being sent as part of a scheduled report? And you want to include section in the notification message? Yes
I don't think this is possible. I have tried to use jsp code to include section but it's not working. Pls check with Pega GCS and raise SR to confirm.
Hello John,
Thanks for writing your query to PSC.
If you are using correspondence rule try the below steps to achieve your requirement:-
1.click on insert rule link
2. Include required section:-
Hope this helps.
Thanks and Regards,
Hari
We are having a similar requirement. Tried using the above option of including the section, but the grid is not formatted in the email body . In below link, it is mentioned as a pega systems defect and we need to use inline CSS. PFB
https://community.pega.com/support/support-articles/structure-data-content-not-maintained-email-body
Can someone pls provide the inline CSS code for the same to get this issue fixed.
Mirunalene
