Engine startUp Failed after updating the Batch Requestor accessgroup
Hi team,
we updated the Accessgroup from PRPC:Agents to POC:XXXXXX for batch requestor to make queue (Asynchronous call) work in activity.
Now queue instruction is working fine,but while restarting the server we are getting issues .PFB logs
Below is the article which explains the same.But we are looking other resolution .Please help
https://pdn.pega.com/support-articles/engine-startup-failed-evaluatewhen-exception-npe
Hi team,
2015-05-19 18:50:36,329 [ ] [ STANDARD] [ ] [ ] ( etier.impl.EngineStartup) ERROR - PegaRULES initialization failed. Server: test.com
com.pega.pegarules.pub.context.InitializationFailedError: PRNodeImpl init failed
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:394)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.getThreadAndInitialize(PRSessionProviderImpl.java:1905)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineStartup.initEngine(EngineStartup.java:657)
Caused by: com.pega.pegarules.pub.runtime.IndeterminateConditionalException: Executable.evaluateWhen-Exception Encountered a :java.lang.NullPointerException
at com.pega.pegarules.session.internal.mgmt.Executable.evaluateWhen(Executable.java:4101)
at com.pega.pegarules.exec.internal.basic.dictionary.AccessInfoConclusion.evaluateConditions(AccessInfoConclusion.java:936)
at com.pega.pegarules.exec.internal.basic.dictionary.AccessInfoConclusion.evaluate(AccessInfoConclusion.java:808)
at com.pega.pegarules.session.internal.authorization.access.AccessEvaluator.haveAccess(AccessEvaluator.java:179)
at com.pega.pegarules.session.internal.authorization.access.AccessEvaluator.haveAccessWithFrame(AccessEvaluator.java:607)
at com.pega.pegarules.session.internal.authorization.Authorization.haveAccessWithFrame(Authorization.java:1913)
at com.pega.pegarules.data.internal.access.Saver.checkSecurity(Saver.java:713)
at com.pega.pegarules.data.internal.access.Saver.save(Saver.java:602)
at com.pega.pegarules.data.internal.access.DatabaseImpl.save(DatabaseImpl.java:4945)
at com.pega.pegarules.data.internal.access.DatabaseImpl.save(DatabaseImpl.java:4931)
at com.pega.pegarules.data.internal.access.DatabaseImpl.save(DatabaseImpl.java:4923)
at com.pega.pegarules.exec.internal.basic.SystemSettingsImpl.setDynamic(SystemSettingsImpl.java:355)
at com.pega.pegarules.cluster.internal.PRClusterImpl.getClusterName(PRClusterImpl.java:311)
at com.pega.pegarules.cluster.internal.PRClusterHazelcastImpl.configureHazelcast(PRClusterHazelcastImpl.java:443)
at com.pega.pegarules.cluster.internal.PRClusterHazelcastImpl.initialize(PRClusterHazelcastImpl.java:354)
at com.pega.pegarules.cluster.internal.PRClusterImpl.getInstance(PRClusterImpl.java:133)
at com.pega.pegarules.cluster.internal.PRClusterProviderImpl.getInstance(PRClusterProviderImpl.java:87)
at com.pega.pegarules.session.internal.mgmt.PRNodeImpl.joinCluster(PRNodeImpl.java:2336)
at com.pega.pegarules.session.internal.mgmt.PRNodeImpl.initializeSystem(PRNodeImpl.java:989)
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:373)
... 36 more
Caused by: java.lang.NullPointerException
at com.pega.pegarules.generation.internal.PRGenProviderImpl.get(PRGenProviderImpl.java:474)
at com.pega.pegarules.session.internal.mgmt.Executable.evaluateWhen(Executable.java:4051)
... 55 more
