Issue
Multiple users are encountering slow engine startups ranging from 40 minutes to 1 hour on starting the Pega server.
Symptoms and Impact
- Pega server takes more than 20 minutes to start.
- Stuck queries display on the pr_engineclasses table.
Steps to reproduce
- Start the Pega server.
- Observe the behavior.
Root Cause
The pr_engineclasses table does not contain database indexes.
Solution
Add the following indexes to the pr_enginesclasses table in the mentioned order of columns only:
- CREATE INDEX RULES_SCHEMA.PR_EC_EXCL_MODIFIED_GCS ON RULES_SCHEMA.PR_ENGINECLASSES ( PZPACKAGE, PZCLASS , PZJAR, PZCODESET, PZCODESETVERSION, PZPATCHDATE );
- CREATE INDEX RULES_SCHEMA.PR_ENGINECLASSES_ALL ON RULES_SCHEMA.PR_ENGINECLASSES("PZCLASS","PZJAR","PZCODESET","PZCODESETVERSION","PZPATCHDATE","PZPACKAGE","PZLASTMODIFIED");
