CTS
Last activity: 18 Mar 2016 0:29 EDT
Application server startup issue after upgrade
After EAR deployment, below messages are found in WAS log. Any body can provide solution for the below?
[3/4/16 19:30:16:001 EST] 000000f2 FfdcProvider W com.ibm.ws.ffdc.impl.FfdcProvider logIncident FFDC1003I: FFDC Incident emitted on /var/WebSphere/Logs/ffdc/PEGACTSPOCSTC1aud4181lS01_de37da1b_16.03.04_ Proprietary information hidden3656881698289831642.txt com.ibm.ws.webcontainer.servlet.ServletInstance.init 181
[3/4/16 19:30:16:002 EST] 000000f2 ServletWrappe E com.ibm.ws.webcontainer.servlet.ServletWrapper init Uncaught.init.exception.thrown.by.servlet
[3/4/16 19:30:16:025 EST] 000000f2 FfdcProvider W com.ibm.ws.ffdc.impl.FfdcProvider logIncident FFDC1003I: FFDC Incident emitted on /var/WebSphere/Logs/ffdc/PEGACTSPOCSTC1aud4181lS01_de37da1b_16.03.04_ Proprietary information hidden4844064265966448518.txt com.ibm.ws.webcontainer.servlet.ServletWrapperImpl 272
[3/4/16 19:30:16:026 EST] 000000f2 PRBootstrap Z com.pega.pegarules.internal.bootstrap.PRBootstrap
[3/4/16 19:30:16:027 EST] 000000f2 PRBootstrap Z com.pega.pegarules.internal.bootstrap.PRBootstrap *=================================================================*
[3/4/16 19:30:16:027 EST] 000000f2 PRBootstrap Z com.pega.pegarules.internal.bootstrap.PRBootstrap prbootstrap.properties missing key for initialization.settingsource
[3/4/16 19:30:16:027 EST] 000000f2 PRBootstrap Z com.pega.pegarules.internal.bootstrap.PRBootstrap NOTE: likely due to using a copy of prbootstrap.properties from a pre-6.1 SP2 install.
[3/4/16 19:30:16:028 EST] 000000f2 PRBootstrap Z com.pega.pegarules.internal.bootstrap.PRBootstrap >> assuming "initialization.settingsource=file"; note that
[3/4/16 19:30:16:028 EST] 000000f2 PRBootstrap Z com.pega.pegarules.internal.bootstrap.PRBootstrap this excludes use of entries in Data-Admin-System-Settings as prbootstrap settings
[3/4/16 19:30:16:029 EST] 000000f2 PRBootstrap Z com.pega.pegarules.internal.bootstrap.PRBootstrap *=================================================================*
[3/4/16 19:30:16:032 EST] 000000f2 PRBootstrap Z com.pega.pegarules.internal.bootstrap.PRBootstrap PRBootstrap.calculateEngineCodeVersionFromDB() - unable to calculate codeset version from database: null
[3/4/16 19:30:16:033 EST] 000000f2 PRMiniLoader Z com.pega.pegarules.internal.bootstrap.PRMiniLoader Will load phase 2 bootstrap from Pega-EngineCode:
[3/4/16 19:30:16:036 EST] 000000f2 PRBootstrap Z com.pega.pegarules.internal.bootstrap.PRBootstrap
============ PegaRULES Bootstrap Configuration ============
Date: Fri Mar 04 19:30:16 EST 2016
Java Version: IBM Corporation 1.6.0
Configuration: <none>
Pega-EngineCode:
(!) Unable to locate classes on filesystem
=============== End Bootstrap Configuration ===============
[3/4/16 19:30:16:037 EST] 000000f2 PRBootstrap E com.pega.pegarules.internal.bootstrap.PRBootstrap Error initializing PRAppLoader
java.lang.ClassNotFoundException: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
