    TCS
Last activity: 7 Aug 2023 10:33 EDT
Failed system startup after upgrade to 8.6.1
In-Place Upgrade is successful for 8.6.1 through IUA, using Tomcat server and Postgres DB. The Bypass Automatic DDL Application was cleared and Update applications schema, Update existing applications and Rebuild database indexes were selected during the Upgrade. But post upgrade the system is not starting. The prweb.war file has been replaced with the one shipped with the 8.6 package. Attaching the logs here.
Couple of logs that stood out were -
1. Encountered bad Data-Admin-DB-Name definition
2. Failed to perform ClosePrprivateJar cleanup, Shutting down cluster provider: HazelcastEmbeddedClusterProvider
Saw an article on similar issue but its for Oracle Db. Is there anything similar for Postgres?
