Upgrade from 7.2.1 to 7.2.2
I'm planning to do a in-place update from 7.2.1 to 7.2.2.Can somebody help me regarding this.
Thanks Sowjenya.
So is there any specific jar file there that i need to request which needs to be deployed.
Could you help me in this part.
Hi Suman,
If you are looking for the PRPC media(which contains all the required files for Pega installation), then kindly raise an SR with GCS team for the Media Request of 7.2.2 version.
Hope this clarifies your doubt.
Regards
Mahesh
Hi Suman,
As you are going for the update process from v7.2.1 to v7.2.2 you need to follow the steps specified in the shared document of Sowjanya.
I had explained you at the high level process to be followed and for the detailed steps kindly look into the shared update document for better understanding.
Hope it is clear to you.
Regards
Mahesh
Hi Suman,
The subject of your post specifies upgrade and message talks about update. If you are looking for upgrade specific then you can look into this document. If it is update then you can follow the document specified by Sowjenya. Hope this might be helpful to you.
Regards
Mahesh
Please refer the Pega 7 Platform UPDATE GUIDE 7.2.2.
Please let me know if this helped.
Sowjenya | Technical Documentation Specialist | Pegasystems Inc.
