Last activity: 29 Sep 2015 11:03 EDT
Did anyone come across this problem: Repeat Grid doesn't show paging!!
I came across an issue with OOTB Repeatin Grid in PRPC 6.3 (or above maybe). When you use the repeating grid in a non harness UI (HTML popup), the paginator is hidden. After analyzing I found that the paginator section uses 'myParamPage' to refer parameters instead of just 'Param'. I want to know if there is a way that we can solve this. couldn't find any hotfix regarding this either.
