Override template doesn't work when add row in Repeat Grid
In repeat grid with options "Expandable rows" and "Override default template", when user adds row by action "Add item", customer's template is replaced by standard "pyGridRowDetails" template instead of what was chosen by them.
STEPS TO REPRODUCE
Create repeat grid.
- Enabled expand multiple rows
- Enabled override template in operations tab
- Run it
- Click on live Ui and trace it
- The template called in override template will not be called on enabling expand multiple rows
Found related post in pdn please refer below for the same Hot fix is available V7.1.7.
https://collaborate.pega.com/question/override-template-doesnt-work-when-add-row-repeat-grid
We are using Pega : V7.1.9.
Please let us know how to fix this issue or is any hot fix is available for v7.1.9 also.
Thanks in Advance
Sambhaji
