Prime Therapeutics
Last activity: 29 Mar 2016 12:40 EDT
Losing date value in parse rule after 7.1.7 to 7.2 update
Losing date value in parse rule after 7.1.7 to 7.2 update.
When we call a service we are tracing the request and response. We can see date values in SOAP response message on tracer. But when the parse rule is applied the date will not transfer to the clipboard properties.
Same service works in other environment which is in 7.1.7 version. Also SOAP UI returns response with dates (ex. DOB) in response. The application code base is the same between the two environments. The only difference is the PRPC versions 7.1.7 and 7.2.
This issue has stopped our update progress to higher environments. We will have to rollback to 7.1.7 if no resolution is known in a timely manner. Need to know if there is a hot fix.
