Date comparison
I need to check 'trans_date'(a variable) is 30 days greater than today's date.How to do this?
Write a When Check like
@differenceBetweenDates(trans_date,@CurrentDateTime(),false,Default)>30
Where do you want to use it?
If you want to use it in activity, approach suggested by Anil will work.
If you want to find out days difference in report, use SQL function pxDifferenceInDays.
