Australian Government
Last activity: 27 Feb 2018 17:57 EST
String comparisons in Pega
Within data transforms, is there any difference in using @equals and == between string properties and/or string literals?
I understand that in Java, using == will compare the object reference even if the contents are identical. But in Pega (and correct me if I'm wrong) it will always compare contents and never the object reference.
I've had LSA/SSA's strongly believe that I should never use == to compare strings in data transforms, and others who believe it is perfectly fine.
Any thoughts on why I would use one over another? On looking at the Java code of @equals I can use it to avoid having to check whether the property has been set (null). It always returns false when one is null. Other than that, am I missing anything else when using == ?
You can check the comparison operators information in below link. It may help you.
https://community.pega.com/sites/default/files/help_v718/procomhelpmain.htm
