TalkTalk
TalkTalk
TalkTalk
Posted: Mar 21, 2016
Last activity: Mar 24, 2016
Last activity: 24 Mar 2016 14:59 EDT
CreateDateTime comparison in Summary View
In summary view of class "Assign-Worklist" I need to display only the results where pxCreateDateTime is after 10/01/2016. Please could you advise how this could be done?
The date will never chane, and I'm using Pega 6.2
Thanks for your help
You will need to add a filter to the Summary View rule, this should be available under a section labeled Criteria. Here you will be able to retreive only results created after 10/01/2016.
Hope this helps,
Sean
Pega Academy Support Team
