TCS
Using windows authentication for SQL Server in properties file
Currently I am able to access SQL Server through windows authentication in management studio. Can we use the same (windows authentication) in upgrade activities?
I tried it in below mentioned ways but still facing the issue.
- Configured windows credentials in properties file.I could see this error "Connection validation failed".
- Configured additional parameter in JDBC URL i.e "IntegratedSecurity=true" and I could see this error "This driver is not cofigured for integrated authentication"
Can we use the windows authentication in upgrade activities or Is it mandatory to use the login credentials?
Rakesh
Use the second appproach.Please ensure that the system(Windows authentication) has access to database. And also place the sql_jdbc_auth.dll file in the windows/system32 folder or in path mentioned for JAVA.
