How we can use unexposed columns in Report Definitions without enabling the CLR with SQL Server. Any ideas?
The alternative for reading BLOB content is using the obj-open method or obj-browse method.
https://community.pega.com/sites/default/files/help_v719/procomhelpmain.htm
Please can you provide more information regarding this. I am getting this issue when I use OOB Duplicate search cases subflow. How to handle it?
Please elaborate what the error is.
>>> OOB Duplicate search cases subflow...
Please share your thoughts/observations/comments, Thank you!
psahukaru
Hi Srujan,
You will not be able to use unexposed columns in a report definition without enabling CLR. CLR is necessary for UDFs to function, which will read the data stored in the blob. If you cannot enable CLR, any property that is needed for the report definition query will need to be exposed as you will not be able to get the property from the blob.
