CBA
Last activity: 30 Oct 2015 11:28 EDT
SLA based on property reference in Assignement ready section
I need configure SLA for One Assignment dynamically. I am uisng PRPC 7.1.7.
In the assignment ready section of SLA there are three options. 1. Immediatly 2. Property reference. 3. Manual time period.
I want use Property reference option baecause I need to fire SLA based on one of the work object property which will enetered in previous assignment.
I tried to configure it but its not working.
Anybody suggest the correct way and explain it clearly?
JP
What Is the type of the property being used? Is it datetime?
Virtusa
Check at runtime if the property has value. If not it wont run. Check how to trace a agent and try tracing the sla agent on its next run, so as to understand if the clipboard has the value when SLA runs
Services Australia
Check this article https://pdn.pega.com/process/how-to-set-the-service-level-agreement-sla-late-event-from-a-property-reference
-Vamshi
CBA
its working fine for me.
Virtusa
Hi Rj_GM123,
Kindly add the solution to close this treat.
harinath
CBA
Solution: The property on which SLA configure should have the value before target assignment and property should be Datetime type.
Citizens Bank
Its not working for me.
1. Referred new property "X" in the SLA rule at "Get Date Time From". "X" has values before it reaches the assignment.
2. Defined and referred new properties "Y" and "Z" as Goal and Deadline properties which also has respective values before reaching the assignment.
3. SLA is not getting invoked. ( added logging at the goal escalation activity to verify but no luck)
Am I missing anything?
Pega
hi Lothith,
As you mentioned that Get DateTime From where you referred X property whether it is an datetime property or only a date property?
System uses the value of this property to compute the deadline time (property Work-.pySLADeadline) and goal time (property Work-.pySLAGoal) for the assignment only once, when the assignment is created.
Later changes to the value of this property do not automatically cause any recomputation of these times.
Reference a property with a DateTime type here; you cannot use Date properties.
Citizens Bank
Its a DateTime property that I have used.
Virtusa
Hi Lohith,
Did you try printing the value of the date time property in the log when the agent picks this up for execution?
harinath
Citizens Bank
Hello All,
I achieved what was required for me. I made control to land on the same assignment thru advance flow.
Thank you all for your responses.
Pega
what was the requirement and why do you require to cofigure an advance flow to land on same requirement.
Could you provide your business requirement.
MAHINDRA SATYAM
I do have similar kind of issue, moreover if goal passes i have to end the flow itself. So in the Escalation activity of Goal i have used ticket. and placed the ticket on End shape.
Can anyone suggest if there can be any other better approach.
Setting ticket in the escalation activity seems to be good approach. Why do you think it is not correct approach?
