Virtusa
Virtusa
Virtusa
Posted: Jun 3, 2015
Last activity: Jan 11, 2017
Last activity: 11 Jan 2017 9:31 EST
Removing/Deleting Rule from private checkout without logging in/using different operator ID
Hi all. I was trying to disable the UI inspector on the case manager portal. So i changed the availability of the Final When rule EnableUIInspector to blocked in Private Edit. Now my operator ID is unable to login and does not display the portal and shows an error(because its unable to find the when rule i guess). How do I delete the checked out rule from my private ruleset without logging in? Also how to remove the UI inspector from Case Manager Portal? Any help would be greatly appreciated.
Delete the when rule from pr4_rule database table which has name="EnableUIInspector" and pyRuleset="@YourOperatorID".
UI inspector will be available if operator has pxUIInspector privilege. Remove this privilege from @baseclass R-A-R-O.
