Standard Chartered
Last activity: 17 Oct 2016 9:03 EDT
Offer flow Invocation
I understand the offer flow and attributes and the various shapes used in the offer flow. However could not understand how the offerflow is called from strategy. Also when there is a limitation on the offer/channel, how the subsequent runs select different users/segments and apply the limitation logic.
Natwest Group
Hello Guru,
I tried running program, its running but not generating any offers. Could you please let me know what all rules I can verify from my side in this regard. Thanks
rgds
karan
Hi Karan
Can you please add more details. When you say the program is not generating offers, which program are you referring to? Is it from one of the Pega Markting courses?
Regards
Guru
Standard Chartered
Thanks. The course do not detail all these.
Can you also please detail how the subsequent program execution do not pick the same customers (segment); Is this done by using Interaction history? Hope earlier execution and it's associated offerflow data can be used for this filteration.
would appreciate under the hook steps (very high level) from NBAA portal perspective too. NBAA is real time and I believe the strategy execution is for every interaction by the customer.
Thanks, Sebasti
Hi ,
I was also curious about the linkage with proposition and offer flow. How pega identifies which offer flow to invoke for a specific proposition? Offer flow name and proposition name should be same? As I can see offer flow identifier should not have space while proposition can have space.
Suppose I have 2 business issue, each of it having 3 groups. I want one single default offer flow for all of them. how to achive that.
Please help me on that.
Saikat
Hi Saikat
In Pega Marketing, there is a one-to-one relation between offers and propositions. In Pega Marketing, when you create an offer, a proposition with the same name is automatically created for you. When a strategy selects a proposition for a customer, the offer flow associated with that proposition is invoked.
Regarding your second query: as of today, there is no way to create offer flows that you can be reused across offers. If there are two offers that have exactly same flow design, you still have to build those flows for both the offers. You can copy an offer (using Save As) to save time.
Regards
Guru
HCL Technologies BV
Hi Guru
While running a Campaign I am getting below error: Exception in Step: Offer Flow.
Could you please let me know how I can trace where the error is happening.
Saikat
Hi Saikat
Does this error occur in one of the Pega Academy exercise systems related to a Pega Marketing course?
If not, then you can try to post it on the PDN Product Support forum.
Regards
Guru
HCL Technologies BV
Hi Guru,
No, actually this happened in our project. We have raised SR for this.
Thanks for the info.
Saikat
