EY
Last activity: 27 Apr 2015 1:16 EDT
How to Close an default tab (like "Home") after Opening one work item tab using java script
we have an IAC requirement where we are openning a work item in tab using a js.
so what we used a harness A and a section B inside that A harness.
Then inside the section B we put a workarea control in workarea control configuration we put tabbed to yes and provide id .Then Put Open By Default row where we mentioned a harness name C.
Then refer the harness A in IAC.
Then in Harness C containg a section D and the section D is containing the java script which is opening a work item in a new tab apart from the home tab which is mentioned in the work area configuration tab.
So currentl we have 2 tab one for default Home tab another is workitem item so now after loading of the workitem tab i want to close the home tab from the js code in section D.
Code inside the section D
function openWorkObjectIAC(){
var a=pega.desktop.getCurrentSpaceName();
alert(a);
pega.u.d.setLabel("Test123456789test233");
//i want to place my code here to close the existing home tab after loading of the workitem in a new tab
pega.desktop.support.closeGadget();
var customAppWindow = null;
customAppWindow = pega.desktop.support.getDesktopWindow();
alert(customAppWindow);
if (customAppWindow != null){
if (typeof customAppWindow.openWorkInPRPCWorkArea == 'function'){
customAppWindow.openWorkInPRPCWorkArea();
</script>
It will be very helpful if any body have any solutions and other thoughts.
thank you SOUMENMAITI for your post
