Error when create new case type: "Update record failed: Improper usage of the choose best ruleset api."
I try to create new case type in a new ruleset on my application, but display this error :
"Update record failed: Improper usage of the choose best ruleset api. User specified a ruleset on the page for a record which either exists in a branch or their personal ruleset."
Tracing the first error is:
"Unable to open an instance using the given inputs: pxObjClass = "Rule-Obj-Class", pyClassName = "UG-CRM-Work-Regolamento35"
Could you help me? How could I resolve this error? Thank you
@EmiliaA8 can you please check if ruleset is included in your application rule stack?
