Add Callback URL - facebook Messengar webhook NOT working
Hi ,
I'm trying to set up the webhook URL ,but getting the attached error .
Hi ,
The below post seems to be similar issue, please check it might be helpful:
https://collaborate.pega.com/question/facebook-callback-webhooks-url-syntax
Rakshith- Thanks! Followed the steps as mentioned in the post but only problem is setting up the web-hook .Web-hook setting is not working .I tried the following :
i. Used my Pega personal edition URL
ii. Used ngrok to make it a secured one .But still getting 500 response code .
Has anyone faced similar issues while configuring the web-hook for pega?
Check access group of the Channel service package it should be same as your template operator's access group
Your webhook points to wrong endpoint. Please change it to https://***.****.com/prweb/PRHTTPService/channel/srv/fb
