Issue
User is unable to launch a local action inside another local action using the out-of-the-box ProcessAction activity by passing all the required parameters.
Environment
Pega Platform 8.8.5
Steps to Reproduce
- Launch a local action in a process flow.
- Launch another local action from the previously launched local action.
- Observe the behavior. At run time, the local action is not rendered on user interface.
Explanation
Launching a local action inside another local action is not a supported configuration. Modal/Overlay can be launched from client side using a button and an action set. It is not possible to directly call ProcessAction activity.
Solution
Launching a modal from another modal is not supported. Launching an overlay from another overlay is not supported. However, you can launch overlay from modal dialog and vice versa.
