Contributed by Mateusz Pyzik
Scenario
You have designed your application to display text (pxTextInput) containing HTML tags using a Label control. The Label text is formatted, instead of displaying as plain text.
By injecting HTML (rather than JavaScript) in pxTextInput, you can give your Labels a more aesthetic look in your application. For example, you might want the name of your organization to display in red text, instead of black text.
Not encoding a property value of a Label control with HTML poses the risk of a cross-site scripting (XSS) attack.
Explanation
You can enable or disable Label formatting by specifying a Dynamic System Setting (DSS) or by validating pxTextInput to prevent the insertion of HTML tags at all, but this requires some custom configuration.
Environments
The problem was reported in the following on-premises environments:
- Pega Platform™ version 8.3.6
- Pega Platform version 8.4.4
- Pega Platform version 8.5.3
- Pega Platform version 8.6
- Pega Platform version 8.7.4
Solutions
This issue was resolved in Pega Platform versions 8.4.4, 8.5.3, and 8.6 and later releases.
Best practice
If you are using a Pega Platform version prior to Pega 8.8, update your deployment. See Keeping current with Pega.
Go to the Pega Support Center Pega Platform Resolved Issues and search for the following items with the title Cross-site scripting protection update:
Resolved Issues for Pega Platform 8.4.4 ISSUE-614989 and ISSUE-612993, Cross-site scripting protections have been updated for labels
Resolved Issues for Pega Platform 8.5.3 ISSUE-598902, ISSUE-614990, ISSUE-612994, ISSUE-620655, Cross-site scripting protections have been updated for labels
Resolved Issues for Pega Platform 8.6 ISSUE-598901, ISSUE-612992, ISSUE-620656, Cross-site scripting protections have been updated for labels
Alternative solution
If you are using Pega Platform version 8.7.4, you can disable Label formatting with HTML by completing the following steps:
- Set the DSS:
Owning Ruleset: Pega-UIEngine
Setting Purpose: pyPreventXSSInLabel
Value: true
- Save the record.
- Resave the affected sections.
Related content
Pega Documentation
Mitigating common security vulnerabilities
About the bulk Revalidate and Save tool
Using the Revalidate and Save tool
Pega Support Documents
Supported Content Security Policy (CSP) for Traditional UI and Constellation UI
Rich Text Editor issues caused by DOMPurifier filters for security
@MaryCarbonara
Hello, We are running Pega 8.7.6. Is it necessary to install a hotfix or is the only solution to upgrade Pega to version 24?
