Issue
The POST /v1/assignments/{id} DX API call returns an IndexOutOfBoundsException in the response.
Steps to reproduce
Create a case with an assignment.
Create a JSON to submit to the /v1/assignments/{id} API that includes a new pagelist property not currently present in the case.
Submit the request to the /v1/assignments/{id} API.
Root Cause
An issue in Pega’s code or rules where updates to the PZAPPLYDATAFORPERFORMACTION results in an IndexOutOfBoundsException.
Solution
Update to the following versions with the fix:
Pega Platform 24.1.2. Search for INC-B18059 and INC-B31660 in Pega Platform 24.1.2 Patch Resolved Issues .
Pega Platform 24.2. Search for INC-B18059 and INC-B31660 in Pega Platform 24.2 Resolved Issues.
Reply has been moved here.
**** Moderator Note *****
@Harish17206477 This support document was specifically for DXAP v1.
As your issue has not been tested using the recommended version, I have moved your question under Pega 24.1.1 V2 DXAPI all returns an ‘IndexOutOfBoundsException’
Users will be able to comment there, and if you still believe this to be a product bug in the recommended release 24.1.2, then please log a support incident via the MSP.
