Why does Customer Profile Designer not display any data sources?
Pega CDH 8.7
the association is simple Customer has Products.
the Customer Context has been pointed to the Target Customer Table, and generates fine (have tried both DB Tables and DDS).
both the Customer Class and Product Class are created as concrete classes, have an associated Database Table, have DataSets created for both DB and DDS, and DataTypes were used to enter sample data.
The generated CustomerData DataFlow works just fine for the Customer Data. but ...
since you can now no longer use the Context Page to associate data, but must use Customer Profile Designer, I have attempted to build the association in the prescribed way.
all DataSets were added as data Sources:
however when you open the Customer Profile Designer, the screen is blank ... no data sources show up.
am I missing something here ?
Pega CDH 8.7
NOTE: I realize that I could just manually build the underlying dataflows to connect the data myself, but I am trying to do this the 'Pega' way ...
***Edited by Moderator Marije to add Support Case Details***
@molaj, @collg1, @shanr2, @achas1
quick update ... I did decide to run the activity as initially advised ... DeleteCPDRule
this does seem to have resolved the issue ... now when I open CPD I see the default CD artifacts ...
of course I would still like to understand the root cause, and any cautions that go with running the clean up activity ...
