Last activity: 23 Jan 2017 12:54 EST
When I run the Localization wizard for the Dutch Locale (nl_NL) with option 'Re-translate existing options' then the translation column in the generated excel file is empty and does not show the translated field values in the localized ruleset RBG_nl. Wha
When I run the Localization wizard for the Dutch Locale (nl_NL) with option 'Re-translate existing options' then the translation column in the generated excel file is empty and does not show the translated field values in the localized ruleset RBG_nl. What can cause this problem?
Our application has many field value rules in the ruleset RBG_nl. When I run the localization wizard for the dutch locale with option 'Re-translate existing options' then these field values are not available in the column Translation in the exported excel. So for some reason the localization wizard is not able to find the field value rules in the RBG_nl ruleset.
The version our Pega development server is 7.1.8
Message was edited by: Vidyaranjan Av| Included Category
