Field Values not translating in column filters
I have seen this issue in other forum posts but no provided solutions have worked. We are developing in Pega 7.3.1 and have multiple tables that source columns from pyStatusWork which has associated field values.
Our table entries translate correctly but the pop-up column filter shows the non-localized text of the field values. One solution that we tried was setting the Filter By condition to Format which did not fix our problem and we would like to avoid implementing a fix using JS.
Multiple SR about this issue are listed as resolved with the introduction of 7.3.1, is there a potential fix I may have overlooked?
Thank you
***Edited by Moderator Marissa to update Content Type from Discussion to Question***
