Qbe Insurance
PH
Last activity: 29 Oct 2015 16:27 EDT
Error running localization wizard
I'm trying to enable the localization for an application but I'm getting an error. I'm using version 7.1.9
Does anyone know what could be causing this error? I've tried in another ruleset where the rules are of rule type Rule-Message and I don't get any issues.
2015-10-15 15:03:06,235 [ PegaRULES-Batch-5] [ STANDARD] [ ] [Application:01.01.01] ( Localize.Rule_.Action) ERROR rachel - &&&:
2015-10-15 15:03:06,243 [ PegaRULES-Batch-5] [ STANDARD] [ ] [Application:01.01.01] ( Localize.Rule_.Action) ERROR rachel - &&&:
2015-10-15 15:03:06,263 [ PegaRULES-Batch-5] [ STANDARD] [ ] [Application:01.01.01] ( Localize.Rule_.Action) ERROR rachel - &&&:
2015-10-15 15:03:06,269 [ PegaRULES-Batch-5] [ STANDARD] [ ] [Application:01.01.01] ( Localize.Rule_.Action) ERROR rachel - &&&:
2015-10-15 15:03:06,554 [ PegaRULES-Batch-5] [ STANDARD] [ ] [Application:01.01.01] (ernal.async.BatchRequestorTask) ERROR rachel - Batch activity "PegaAccel-Task-Localize.VerifyLocalizationIsOn" threw:
com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:712)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivities(ThreadRunner.java:572)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivities(PRThreadImpl.java:453)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.executeBatchTask(QueueProcessor.java:257)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:320)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:945)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1259)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:901)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:670)
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:991)
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:532)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.StackOverflowError
at java.util.regex.Pattern$BranchConn.match(Unknown Source)
at java.util.regex.Pattern$Curly.match1(Unknown Source)
at java.util.regex.Pattern$Curly.match(Unknown Source)
at java.util.regex.Pattern$Branch.match(Unknown Source)
at java.util.regex.Pattern$GroupHead.match(Unknown Source)
at java.util.regex.Pattern$LazyLoop.match(Unknown Source)
at java.util.regex.Pattern$GroupTail.match(Unknown Source)
